View unanswered posts | View active topics It is currently Thu Sep 09, 2010 1:11 am
Reply to topic  [ 5 posts ]
Mesa Dual Rectifier 3 channels
Author Message
Post Mesa Dual Rectifier 3 channels
Hi,
my RG-16 configured (function switch 4 button held down while reconnecting the power plug) with Cable part #AC-RRN-10 is working like this:
function switch 1 : channel 1
function switch 2 : -
function switch 3 : channel 3
function switch 4 : channel 2
function switch 5 : -
function switch 6 : solo
function switch 7 : -
function switch 8 : FX Loop
Is it ok ? I would expect f.switch 2 : channel 2 (instead of f.switch 4)
Regards,
Jérôme
Thu Feb 25, 2010 9:33 am
Profile
Site Admin
Post Re: Mesa Dual Rectifier 3 channels
That's definitely wrong... I'm thinking that your cable was wired incorrectly. You can send it back to us to get it fixed if you like...
Thu Feb 25, 2010 9:37 pm
Profile
Coming back to "no switches momentary or grouped default setting" (Hold Function Switch 1), I can't hear relay 2 switching when I play with function switch 2.
RG-16 is the cause !
Thanks for your quick reply.
Regards,
Jérôme
Fri Feb 26, 2010 7:15 am
Profile
Site Admin
What are you using to power the RG-16? Powering it with 9VDC (instead of 9VAC or 12VDC) is the most common cause of relays not switching.
Fri Feb 26, 2010 10:40 am
Profile
That's right, my power supply was a bit low... Strange that only one relay didn't switch.
Anyway, now everything is working fine.
Thanks again for your support.
Regards,
Jérôme
Sun Feb 28, 2010 3:09 pm
Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
cron
Designed by STSoftware.
